Author: Subject: WTD: MX5 NA parts..
posted on 4/4/14 at 06:31 PM Reply With Quote
WTD: MX5 NA parts..
Mazda MX5 Mk1 NA spec front and rear uprights with disks and calipers, driveshafts and a PAS rack.
WTD?
Thanks,
scimjim
posted on 4/4/14 at 07:30 PM Reply With Quote
I have a stripped rolling chassis (engine/box etc used in a project) - uprights, dampers, brakes, diff, etc still fitted or on the shelf - only bit I can't supply is the rack.
Collection only from Gloucester/Cirencester I'm afraid - but cheap.
posted on 4/4/14 at 07:38 PM Reply With Quote
Thanks, 500 mile roundy ouch!
scimjim
posted on 4/4/14 at 08:10 PM Reply With Quote
Ah - sorry, I didn't have the first idea where "Hetton del sol" was
posted on 4/4/14 at 08:16 PM Reply With Quote
Ah, see you need to be in the know
PorkChop
posted on 4/4/14 at 09:01 PM Reply With Quote
Do you need 1600 or 1800 bits? The brakes are different but interchangable, the driveshafts aren't interchangable.
posted on 4/4/14 at 09:24 PM Reply With Quote
They just need to be NA spec. 1990~1997. Need the matching rack and front uprights. Rear uprights can be NB but would prefer, for simplicity, NA parts all round. And, knackered drive shafts are OK, only need the upright end, stub axle bit really..
posted on 3/1/15 at 10:24 AM Reply With Quote
Still on the look out for these parts....
PorkChop
posted on 3/1/15 at 12:43 PM Reply With Quote
I thought you were sorted Steve?
I still have those parts...
posted on 3/1/15 at 12:51 PM Reply With Quote
Cheers, which bits you got? Still got the jeep to finish which I haven't touched now since summer...2014...
PorkChop
posted on 3/1/15 at 01:28 PM Reply With Quote
2 x front uprights (bare)
2 x pairs (so 4 in total) 1600 bolt on driveshafts
1800 front calipers and mounts
1800 rear caliper mounts
Might have a pair of rear calipers
I have a set of rear uprights with 1800 push on driveshafts stuck in them, can't get them out for love nor money, but I'm not going to be sending those through the post I'm afraid.
big_wasa
posted on 3/1/15 at 01:45 PM Reply With Quote
I pushed my shafts out with a 3 leg puller.
PorkChop
posted on 3/1/15 at 02:51 PM Reply With Quote
You were lucky then. Lots of them need big presses if they come out at all.
posted on 3/1/15 at 03:42 PM Reply With Quote
Where are you choppy?
Can u not use myherme?
PorkChop
posted on 3/1/15 at 04:18 PM Reply With Quote
U2U'd Steve
