lewis635
| posted on 19/7/05 at 08:53 PM |
propshaft splines
I need the front piece of a propshaft to enable me to get my prop made,
i have the prop to diff end so need the prop to gearbox splined end
it is to mate to a ford rocket box
was hoping some of you BEC boys might have a spare.
or if anyone has a full prop i would be interested.
thanks
| posted on 19/7/05 at 09:19 PM |
hi lewis. I have 3 props, i can cut off the front part if you want sometime. Im up in cumbernauld in a few weeks. All type 9 props.
DarrenW
| posted on 20/7/05 at 09:20 AM |
The front piece that fits gearbox is called the 'Nose'. Mac#1 sell the front nose with first UJ, you simply weld the tube onto the boss at
the back of the UJ. You need to specify the tube diameters.
lewis635
| posted on 20/7/05 at 05:57 PM |
Thanks guys.
when are you in cumbernauld joel?
mad-butcher
| posted on 20/7/05 at 05:59 PM |
no disrespect intented but make sure you get it welded by a pro (wouldn't like that F####R letting go by my legs) but there again having seen
the state of the welding by a so called chassis builder on kitcar crisis .......seriously make sure it's welded properly if the weld does give
way it's bad
tony
lewis635
| posted on 20/7/05 at 06:07 PM |
Yeah dont worry i am getting it done proffesionally but require both ends of the props for them to make it up.
Thats one part of the build i would never try to save a few bob on. just not worth it.
| posted on 20/7/05 at 06:28 PM |
im in cumbernauld around the first few days of august. The props i have are all rubber donut ones rather than universal joint ones - are these not
what you're after?
lewis635
| posted on 20/7/05 at 06:46 PM |
doesnt really matter joel, all i need is the splined (or nose) end. just cut off at the end of the shaft.
however i work offshore and i am back at work on the 1st of august.
