coovey
| posted on 30/8/05 at 05:29 PM |
Rubber brake hose
I failed SVA today and one of the fail points was not being able to provide prove that the rubber hose I had used to connect the Brake reservoir to
the master cylinders was up the the job of carrying brake fluid.
So I need to source a metre of 5/16 bore rubber hose with documentation from the manufacturer that says it can carry brake fluid. it won't be
taking too much pressure it really needs to be the correct rubber to take brake fluid is the main thing.
Any ideas on a source?
| posted on 30/8/05 at 07:09 PM |
Think Automotive sell it , may be worth a search as i'm sure this was covered not that long ago.
scutter
| posted on 30/8/05 at 08:01 PM |
See my reply in the SVA section.
We'll sort you out
Dan.
coovey
| posted on 31/8/05 at 10:41 AM |
Thanks guys.
I have ordered some from fuelsystems as it appears this will be acceptable with the datasheet and the markings on the hose that tie up.
