Author: Subject: Rear Fill Rocker Cover
Simon F27
posted on 18/9/05 at 09:03 AM Reply With Quote
I need to know where I can get hold of a modified pinto rocker cover with rear oil fil, or if there is some place that will modify for you.
marshall
posted on 18/9/05 at 11:14 AM Reply With Quote
hi i need mine done to i was going to ask tiger how much it was going to cost hope some one helps
Jon Ison
posted on 18/9/05 at 11:26 AM Reply With Quote
Its a pretty easy job too do yourself if you have a welder or know someone who as..........
just remember too put some sort of baffle plate behind it too stop oil splashing around and finding its way out thru the mesh gauze in your filler cap........
Failing that do the prop work and get a local fab shop too weld it up for you, they will do it for the cost of a pint if you do the prep work.
bob
posted on 20/9/05 at 11:08 AM Reply With Quote
Could be a bargain,just found it by chance.
http://cgi.ebay.co.uk/PINTO-CAMCOVER-with-extra-breathers_W0QQitemZ8000400081QQcategoryZ72205QQrdZ1QQcmdZViewItem
mad-butcher
posted on 20/9/05 at 07:07 PM Reply With Quote
why?
