BKLOCO
| posted on 27/1/06 at 11:17 AM |
Zetec info
Can anyone who has a 2.0litre Mondeo tin top haynes manual help me out?
I need some info for setting up my MegaSquirt.
I need to know wht the Max Torque figure is and at what revs it is developed and the max BHP figure and again at what revs.
The third spec I need is a little more obscure and I'm not sure it will be in the Haynes manual but I need to know how much fuel the standard
injectors are capable of flowing, in either CC's per minute or lbs per hour.
Any help appreciated.
ecosse
| posted on 27/1/06 at 11:32 AM |
This site will help with the power figures, and I'm sure someone will have the injector info
or know where it is
Alex
stevebubs
| posted on 27/1/06 at 11:51 AM |
if you ask, I'm sure there's a few people around here with base maps you can use as a starting point...
piddy
| posted on 27/1/06 at 02:56 PM |
Try asking on This Group.
iank
| posted on 27/1/06 at 03:38 PM |
Got Haynes book open
Pre 4/1998 100kW @ 6000 rpm
Post 5/1998 96kW @ 6000 rpm
No torque figures to be found, or injector flow rates.
suspiciously round numbers for rpm IMO
probably useless I'm afraid.
stevebubs
| posted on 27/1/06 at 04:19 PM |
Locally, a search for "zetec map" turns up
this and
this
and this
BKLOCO
| posted on 27/1/06 at 05:45 PM |
Thanks for the replies so far.
I forgot all about the Zeetec Cat site
That has the power/torque figures I needed for generating the base maps.
I still need the injector flow figures if anyone can help. if not I guess it will be a call to the Ford Technical help line at £1.00 a minute
iank
| posted on 28/1/06 at 07:33 PM |
Injector fuel rates are here (found link in PPC letters page )
http://www.rsparks.com/tech_ref/fuel_injectors.html
Will need the serial numbers of the injectors as the list is rather UScentric in the vehicles column.
stevebubs
| posted on 28/1/06 at 09:38 PM |
If grey, they're apparently 330cc/min (just seen another post with this in)
BKLOCO
| posted on 29/1/06 at 01:28 PM |
Thanks for that Stevebubs.
That sounds about right.
I was estimating about 500cc/min from some rough info I got from an Aussie tuning site that listed some Nippon Denso injectors
A value of 330 will give me a much better injection time in milliseconds as at 500 it was way too short.
