Author: Subject: Sierra fornt calipers
BKLOCO
posted on 10/4/06 at 07:09 PM Reply With Quote
Despite fitting new seals to my Sierra front calipers I'm still having trouble bleeding the buggers.
Where is the cheepest place to get new/recon. I'll ring my local motor factors in the morning but just wondered if anyone knew of any cheap suppliers.
Gav
posted on 10/4/06 at 07:22 PM Reply With Quote
Have a look at www.brakesint.co.uk
Danozeman
posted on 10/4/06 at 09:15 PM Reply With Quote
What about this place??
Big red.
Dan
Schrodinger
posted on 11/4/06 at 11:50 AM Reply With Quote
This may sound a bit stupid but have you got them mounted on the correct sides so that the bleed nipples are at the top?
DarrenW
posted on 11/4/06 at 12:08 PM Reply With Quote
Fronts - I got mine for £28 each exchange from local motor factors (Coulthards, Bishop Auckland). AMK???? or something like that. i bet loads of places local will do them if you shop around.
posted on 11/4/06 at 01:23 PM Reply With Quote
desscribe the problem and how you are bleeding them.
posted on 11/4/06 at 01:26 PM Reply With Quote
Or, in my case, when I bought recon calipers I was given 2 right-hand ones (or was it 2 left-hand - anyway, you get the idea!
BKLOCO
posted on 11/4/06 at 05:08 PM Reply With Quote
Thanks for the idea David but yes they are on the right sides.
With regard to "how am I bleeding them"
I have tried loads of ways!
started with the shortest run first working towards the longest then longest to shortest (no different) I'm using a one man non return valve bleed tank and pumping the pedal with the bleed screws open approx 1/2 turn.
The system seems to bleed OK. no bubbles in the clear plastic bleed pipe. the pedal semms firm the first time you press it after bleeding the complete system but then goes "spongey" and needs 2 or 3 sharp pumps to get it solid again so it's definately air.
My guess is its the front calipers as the rear cylinders are new.
flak monkey
posted on 11/4/06 at 05:11 PM Reply With Quote
Before shelling out on a pair of new calipers, get yourself a Gunson Eezi Bleed or borrow one, loads of people have them. They are much better than those one way valve things, and will clear the stubbornest air out of the system.
If that doesnt fix it, get some new calipers, and then you still have the best tool for bleeding them in your inventory
Sera
http://www.motosera.com
