darrens
| posted on 17/7/06 at 10:14 PM |
rover V8 Injection Stepper Motor Air Bypass Valve
As above, more commonly known as the Air Bypass Valve.
mark chandler
| posted on 18/7/06 at 06:53 AM |
hot wire or flappy box, I have a flappy one you are welcome to.
Regards Mark
Agriv8
Darren,
Hotwire of flapper ?
Regards
Agriv8
darrens
| posted on 18/7/06 at 06:16 PM |
Hotwire type I believe, it is the attached if that helps (although photo is crap)
mark chandler
| posted on 18/7/06 at 09:21 PM |
hot wire, have you tried thinners to clean it and WD40 to lubricate ?
Rgds Mark
Agriv8
| posted on 19/7/06 at 06:59 AM |
darren does it move at all make any buzzing noises.
mine is the same hotwire system and at switch off it always gives a buzz and a click - I belive this is normal.
Mine seems to work as even with a very lumpy cam tickover is maintained
darrens
| posted on 21/7/06 at 11:14 PM |
does bugger all, always in the fully re-tracted position i.e letting air in all the time.
Tried the old wd40 thing o no avail, then accidentally shut th boot on it and cracked it. Now it definitely doesn't do anything.
