matt_claydon
| posted on 19/7/06 at 03:21 PM |
3 bar fuel pressure regulator
Anyone got a spare fuel pressure reg they want to sell? Needs to be 3 bar with normal push-on connections for fuel hose and a vacuum connection.
Matt.
muzchap
| posted on 19/7/06 at 04:03 PM |
Most fords have them Fiesta XR2i etc - any injected CVH running EFI should do the trick
HTH
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
DarrenW
| posted on 19/7/06 at 04:16 PM |
Is 3 bar approx 44psi? Is that EFi type pressure?
muzchap
| posted on 19/7/06 at 04:18 PM |
Think so - mines set to 3bar and runs my Zetec fine on fuel injection
Or, if you want to spend a bit more - just get a FSE Fuel Pressure Regulator off ebay, I got mine for £20 second hand - they are universal so just buy
any and fabricate own bracket.
You'll need to check the pressure though - some idiot had set mine to 6 bar!!!! IDIOTS!!!
