se7ensport
posted on 12/3/07 at 07:20 PM |
Pinto spark plug adapters / inserts
4 Spark plug Adapter Inserts that convert from the Std 18mm Pinto Spark plugs so that I can run 12mm Motorbike spark plugs required, cash waiting.
Alex
jacko
posted on 12/3/07 at 07:51 PM |
Do they make them?
se7ensport
posted on 12/3/07 at 08:04 PM |
Yep,
li
nky
SpeedPro Pinto tuning book also mentions them if you raise the CR significantly.
posted on 12/3/07 at 11:46 PM |
18mm plug hits the piston & running these inserts the plug cant hit the piston + you get a much better spark.
How does the plug hit the piston, plugs don't move? Why is the spark better from a bike plug? They run on the same electrics as the other plug.
The only thing they are doing is taking the spark outside the combustion chamber, can't you get shorter reach 18mm plugs to do that?
posted on 12/3/07 at 11:56 PM |
If you skim the head a lot to raise CR the piston wallops them!
se7ensport
posted on 13/3/07 at 07:43 AM |
Possibly, I'll be giving Burton a call the second they open, it'll be a lot cheaper
se7ensport
posted on 13/3/07 at 09:07 AM |
No longer needed, short tip plugs are the solution. Part number NGK A7FS.
