Author: Subject: tiger performance kit or equivalent parts wanted
jimbona2
posted on 30/5/07 at 01:57 PM Reply With Quote
i need all the bits within the tiger performance kit if anyone has any of the equivalent parts lying around?
I have a 2 litre silver top zetec so i'll need 45 webbers but thats all i know
thanks
Schrodinger
posted on 30/5/07 at 02:07 PM Reply With Quote
I would suggest that you use something other than the Alpha ecu as it can only be tuned by an Alpha dealer.
Keith
Aviemore
cadebytiger
posted on 30/5/07 at 03:22 PM Reply With Quote
if i were going from scratch i would go the throttle body route.
you can pick up gsxr 1000s throttle bodies and the ECU to run them for not much more than webbers.
or if feeling a bit flush go for jenveys
You have the added cost of a high pressure fuel pump and swirl pot but you will make this back just in fuels saved withing a year.
If you are going to go for webbers then make sure you get a matched pair! I think the progression drillings can be a problem on the zetec. ( these add more fuel to smooth out the bit between the idle and main jets).
So a shopping list for you is:
Carb Route -
1.Carbs - either weber 45s or bike carbs (not sure which)
2.manifold
3. either ECU or a modified dizzy
4.low pressure fuel pump and regulator
5.Air filters
6.Rolling road or some skill to set the carbs up
Throttle bodies
1. bodies , injectors, fuel rail - jenveys or gsxr1000s
2. Manifold
3. ECU - megajolt/squirt (not sure about these but there is alot of info on how to get this working on here plus alot of help from people). Something like and emerald ECU
4. low pressure fuel pump - swirl pot - high pressure fuel pump
5. air filters
6. Rolling road or a map from someone on here with similar setup
I'm sure people can add to these list and tell me what i got wrong but it's a start
Good luck
Rupert
jimbona2
posted on 30/5/07 at 04:42 PM Reply With Quote
i might be going for the Dunnell Zetec ecu thats going for sale on here
should that be okay?
thanks as always
