darrens
posted on 1/7/07 at 02:27 PM |
7" or 7 1/2" LSD Ford
As above, either will do with the bolt on flanges.
bob
posted on 1/7/07 at 03:15 PM |
Looks like there will be a franzy for this NOS part and doesnt even stsate if its LSD.
Diff
aerobrick
posted on 1/7/07 at 04:06 PM |
Strange thing is even though it has a nice white lable where is the nice new diff tag also the breather and pipe is missing ??
For a part allegedly never used why are these bits missing ?
mark-wiring
posted on 1/7/07 at 09:37 PM |
They both use diff size drive shafts so you need the ones that match your outer hubs so which ones are they?
http://www.v10viento.co.uk
Have to recommend
http://www.extraefi.co.uk/
For all Megasquirt needs
darrens
posted on 3/7/07 at 06:20 PM |
Now tha's lost me, I though that the outer flange (with the many bolt holes) were all the same size, it was just the splines that were
different.
mark-wiring
posted on 3/7/07 at 06:27 PM |
Splines are the same shafts are diff sizes.
Basicly the 7.5inch diff (cosworth) has bigger flanges and larger bolts.
The 7inch ( normal sierra) smaller ones.
Although there is an exception to every rule the granada cosworth has a 7.5inch diff with the smaller flanges.
I know this as i have just done a diff change on my brothers 4i that has full cosworth running gear and the only diff we had spare was a granada
cosworth one and we had to get the flanges swapped over.
Have to recommend
ChrisGamlin
posted on 10/7/07 at 12:10 PM |
There's a 7.5" 3.36 with LSD for £200 on the Westfield forum (www.WSCC.co.uk
Minicooper
posted on 10/7/07 at 01:02 PM |
I have 2wd cosworth diff from a 60,000 mile car, 7.5 lsd 3.64 ratio, I have removed the rear lug on the diff cover, so it needs a little plate welded
or rivetted on
The inside of the diff is sparkling, the oil crystal clear
£120 Chandlers Ford, Hampshire
[Edited on 10/7/07 by Minicooper]
repper
posted on 10/7/07 at 06:42 PM |
hi all iam in the proses off braking a sierra XR4X4 on a 1988 the diff is a 7" and bolt on shafts was going to keep as a spaire its still in at
the momo but its yours if you stuk
my email is hotrodbob@hotmail.co.uk
[Edited on 10/7/07 by repper]
