Author: Subject: xflow belt pully (where can i get one? new or secondhand)
thunderace
posted on 18/9/07 at 11:13 AM Reply With Quote
hi anyone got a belt pully for a xflow engine 3 wheel type (17mm alternator w/pump crank)i dont want to buy a burton one .1" wide with the 3 wheels toothed belt or v groove one.
looking for new or secondhand
[Edited on 18/9/07 by thunderace]
posted on 18/9/07 at 11:18 AM Reply With Quote
I take it is not the stadrd 10 mm V-belt type - those you can buy from halfords - they are out on display and the part number includesthe length in mm. (825 sticks in my mind).
Or is it the aftermarket fitment of a wide toothed belt? again I would be surprised is this was not an off the shelf part so again halford is your friend.
I'd would not recommend buying a used alternator/pulley belt.
jabs
posted on 18/9/07 at 11:20 AM Reply With Quote
I may be wrong but he is asking where you can get a belt pulley not a pulley belt. ie the pully and not the belt
trextr7monkey
posted on 18/9/07 at 02:45 PM Reply With Quote
We will have bog standard x flow water pump and crank pulleys in a box somewhere if you are desperate
