Author: Subject: WTD R1 Sump
StevieB
posted on 23/1/08 at 07:27 PM Reply With Quote
WTD R1 Sump
I'm in need of an R1 sump for a 2000 5JJ as I broke my first one and the second I got has a problem with the sump plus threads (ntdwm I don't think, but the oil keeps leaking nevertheless!)
If anyone should just happen to have one lying around doing nothing, I can find it a nice home in exchange for cash!
jkarran
posted on 23/1/08 at 08:41 PM Reply With Quote
Is the copper washer fitted? PTFE tape is cheap
jk
StevieB
posted on 23/1/08 at 09:15 PM Reply With Quote
I've tried a copper washer, PTFE tape and an o-ring. I've also tried combinations of the above but with no effect.
When I tighten the plug, it gets tight then loosens up - when I took the plug out to inspect it, it had bits of aluminium in the threads, which leads me to believe it's beyond quick fixes.
Using a helicoil has been suggested, which I may as well give a go since I'll need to find a new one if it doesn't work.
Coose
posted on 23/1/08 at 09:27 PM Reply With Quote
Yep, the sump doesn't sound well.....
D'OH!
Spin 'er off Well...
StevieB
posted on 23/1/08 at 09:37 PM Reply With Quote
I think I need to buy a bulk load of sumps because they seem to be a sundry item at the moment!
[Edited on 23/1/08 by StevieB]
jkarran
posted on 24/1/08 at 01:09 AM Reply With Quote
I went through a phase like that, resorted to buying a TIG and fitting a kevlar sumpguard
The little bugger still leaks!
jk
Coose
posted on 24/1/08 at 05:08 PM Reply With Quote
Hmmmm.... Maybe I should get the TIG fired up? Steve - if you can make a steel plate to bolt the sump to to stop it distorting I can have a go at both of your damaged ones. It would need to bolt through all bolt holes into the steel though.
StevieB
posted on 24/1/08 at 05:32 PM Reply With Quote
Might have to be the way forward (at least with two to play with, it's worth a go)
Probably best to try and fix the original 'accident' where it's just the corner lug that@s munched up and shouldn't effect oil retention.
I'll get some steel plate at Rufforth next week.
JK - I wouldn't mind if the sumps were breaking while out driving - the problem is that the car's never even been on wheels yet! Must be some fairy's sneaking in at night and over tightening the bolts or something!
Coose
posted on 24/1/08 at 06:16 PM Reply With Quote
Oh yeah, I'd forgotten about Rufforth. Should I meet you there or pick you up en route? I'm sure Mark will be going but not until the evening....
[Edited on 24/1/08 by Coose]
StevieB
posted on 24/1/08 at 06:47 PM Reply With Quote
Oh yeah, you do the entusastic early thing, I forgot!
I'll meet you next to 'starbucks' at a reasonable time!
Coose
posted on 24/1/08 at 08:08 PM Reply With Quote
Oh, I won't be THAT enthusiastic - I do that when I go with Cider Sam! I just like to get there before everyone else leaves!
StevieB
posted on 24/1/08 at 08:11 PM Reply With Quote
Yeah - last time I still needed a few bits when everyone packed up and left
