nib1980
posted on 8/2/08 at 02:45 PM |
URGENT Wanted - Xflow sump 1.3
Hi all,
came home today looking forward to a trip in the car and taking a mate out, and noticed a large patch of oil on garage floor.
It appears I've holed to sump!
so wanted is a sump for my 1.3 flow.
cash waiting.
Many thanks
short track 123
posted on 8/2/08 at 02:47 PM |
Could It be Welded?
Jason
nib1980
posted on 8/2/08 at 02:52 PM |
only temporary, it's grounded the sump plug and sump, i'm working on that now, but will need a new one for serviceing
posted on 8/2/08 at 03:11 PM |
if you are handly with the wlder, they you could weld a thicker bottom plate and move the sump plug to the side.
halfords sell a variety of sump plugs, weld in a nut on the inside and job done - the copper washer would do the sealing - and before any one say it.,
it does work as I did this on my v8 sump for a oil temp sender.
nib1980
posted on 8/2/08 at 03:21 PM |
hmm interesting may doo that if no one else turns up one
paulf
posted on 8/2/08 at 04:46 PM |
Did my shortened xflow sump like that, i welded a 1.5mm bottom on and made a drain plug and boss to weld to the side .
Paul
gazza285
posted on 8/2/08 at 05:52 PM |
[cough] Here's one on eBay, what a coincidence.
Crossflow sump
r1_pete
posted on 8/2/08 at 06:16 PM |
Got one off a fiesta x flow, brand new, cover the postage and its yours. Will go and get some pics...
Pics in my archive folder - sump
[Edited on 8/2/08 by r1_pete]
nib1980
posted on 8/2/08 at 06:39 PM |
Hi Pete, many thanks for the offer, but Mine is from a Escort RWD, and I suspect the sunps are different.
Unless someone can confirm different??? (please)
again many thanks
paulf
posted on 8/2/08 at 09:42 PM |
Yes they are slightly different , the fiesta one is a front bowl and the mounting holes are slighly different so would need a fiesta type timing
cover, which in turn needs the correct fiesta cam sprockets or else they wear through the timing case as soon as the tensioner wears a bit, guess how
i found out.
Paul
again many thanks
[Edited on 8/2/08 by paulf]
