Author: Subject: Wanted handbrake cable end nipples
jollygreengiant
posted on 16/6/08 at 06:28 PM Reply With Quote
Yes I think this has been covered before but I can't find the answer for looking, so here is the question. I'm sure that someone out here has the answer.
Ok so apart from the usual of a freindly RAC / AA van where else could I obtain spare clamp on nipples for hand brake cables.
I've moved my hand brake lever and fitted a re-inforcing triangulation support on the rear mounting so now the Ford quadrant fouls the braket so I will have to come up with another longer /different attachment to the handbrake lever and I was thinking Peugeot rod and screw on / adjustable pick up attachment bar but that would need a nipple for each cable end IF available. Clamp on nipples in this case would be an ideal solution.
tomblyth
posted on 16/6/08 at 06:59 PM Reply With Quote
bin the car cables and use universal clutch cables from Hein Gerick the bike shop!(£2.99 each) they are the same size steel cable in a thinner sleeve. they also come with screew on nipples. Ill put photos of mine onto here in the next few day's
[Edited on 16/6/08 by tomblyth]
