001Ben
| posted on 4/9/08 at 09:35 PM |
Wanted: Dynojet Kit
Does anyone have a dynojet kit for sale for a 2001 R1 engine or can you suggest a good supplier?
Triggerhappy
| posted on 5/9/08 at 05:28 AM |
This guy´s bit´s is even better: http://www.ivansperformanceproducts.com/carbs.htm
Mind you that the original carbs on the R1 is very sensitive for airbox modifications.
The throttel responce is near to catastrophic if not original airbox is used.
Solution: Original airbox, not modified...make sure fresh/cold air supply.
Had the --00 bike an fiddled a lot on dyno with it and it small to no gain to alter inlet side. But it was very easy to destroy throtle
responce...just open air supply and it was BAD!
Paul TigerB6
| posted on 5/9/08 at 07:04 AM |
I see Demon Tweeks stock the "Stage 1" Dynojet kit for the R1 and they are local to Ben (and myself). Is this the correct kit for a BEC??
Seems to be the same as TTS have on their site??
