mr henderson
| posted on 24/9/08 at 09:41 AM |
What is good value in tube notchers at the moment?
Need to do some round tube work soon, and I will need to do some tube notching (or bird's mouth cutting if you prefer).
There's nothing suitable on Ebay at the moment, and I'd prefer not to buy from the States unless there's nothing to be had from the
UK.
Anybody know of anything? It needs to cut a 25mm radius notch (to fit onto 50mm tube) BTW
John
andyharding
| posted on 24/9/08 at 10:21 AM |
Round file 99p on ebay:-
SeaBass
| posted on 24/9/08 at 10:34 AM |
Best thing I've ever seen...
wilkingj
| posted on 24/9/08 at 10:44 AM |
use the cardboard / toilet roll trick and cut the end to match the joint. then slip over the tube, mark out and notch up the tube.
I have seen a home made one, using some steel rods and plastic drain pipe tubes.
The rods form a sort of circular profiling Comb affair (between the two plastic tubes), which you offer up to the point where you want the notch. They
move and form around the tube you are welding to.
The you use the formed rods to mark out on the end of the tube you want to cut.
Or...
http://www.chesteruk.net/store/tube_notcher.htm
Same thing from then USA but only $54)
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=42324
There is plenty of articles and stuff on forums if you do a google search.
have fun..
Best Regards
Geoff
http://www.v8viento.co.uk
Mr Whippy
| posted on 24/9/08 at 11:08 AM |
well smart that but I bet it is pricey
mr henderson
| posted on 24/9/08 at 11:13 AM |
Or...
have fun..
I did indeed do a Google search but what I really want to do is to buy a tube notcher rather than to read about them
Unfortunately the Chester tools people don't have any, and Harbor Freight don't seem to export to the UK, so I'm still in the market
if anyone knows of any other sources (ideallyin the UK)
John
locoR1
| posted on 24/9/08 at 11:21 AM |
All you want is a thin 1mm cutting disc in your angle grinder and download the tubemiter program from the first post on the mig welding forum
here:http://www.mig-welding.co.uk/forum/showthread.php?t=791
Did my roll cage tubes using it works a treat angles and different tube sizes no problem.
Check out my CB500T Cafe Racer build diary
adithorp
| posted on 24/9/08 at 11:35 AM |
Frosts do one. Not cheap though.
http://www.frost.co.uk/item_Detail.asp?productID=8470&frostProductName=Tube+Notcher+%28without+tools%29&catID=13&subCatID=19&FrostCat=
Bodywork&FrostSubcat=Machines
adrian
http://jpsc.org.uk/forum/
Agriv8
| posted on 24/9/08 at 11:47 AM |
have a look here
Northern tool US
they have a UK branch but they dont apear to list them ( but could possibly get you one ) worth an email ?
regards
Agriv8
mr henderson
adrian
I don't think that one does angles?
John
mr henderson
| posted on 24/9/08 at 11:49 AM |
I do have that program, and will probably use it if I can't get what I want. It's just that I expect to be doing a fair few of these so
it's worth a bit of investment.
John
Minicooper
This is where I bought mine, nicely made and quite substantial, more expensive than the cheaper ones on ebay but a better quality machine
http://www.rollcentre.co.uk/rollcentre/html/rollcage_additions.html
Paul TigerB6
| posted on 24/9/08 at 11:50 AM |
Another one here - does angles up to 60deg and up to 2" pipe - £150
linky
Ha typical - David beat me to it by less than a minute!!
[Edited on 24/9/08 by Paul TigerB6]
Richard Quinn
| posted on 24/9/08 at 12:28 PM |
The Chester UK one is pretty good (and good value). Did they give you any indication as to whether they would get them back in stock?
nitram38
| posted on 24/9/08 at 01:08 PM |
I have the chester one. I bought it for the MotaLeira and never used it!
I found it easier to hold the end of the tube agaist the other and mark with a marker pen, then cut the curves out with a worn grinding disc (layered
paper type) until it fit.
It is just as much hassle trying to get the tube notcher to be at the correct angle as it is to do them by hand.
If I had 100 identical ends then I would use the notcher................
Minicooper
| posted on 24/9/08 at 01:29 PM |
You need an angle indicator nitram, makes it very easy
nitram38
| posted on 24/9/08 at 02:25 PM |
Too late now!
| posted on 24/9/08 at 03:14 PM |
A drum sander with some 40 grit sleeves in the diameter you need.
IDONTBELEIVEIT
| posted on 24/9/08 at 05:30 PM |
correct size holesaw and drill through the pipe two birdsmouths for the price of one
Are We There Yet, Are We There Yet!!!!
mr henderson
| posted on 24/9/08 at 06:01 PM |
Easier said than done, most tube notchers use a holesaw anyway, problem is to get the hole in the right place
| posted on 24/9/08 at 06:17 PM |
indeed, bloody hard work. In fact if you're doing an angle, i'd say impossible. It snags far too much with a pillar drill.
Neil P
| posted on 24/9/08 at 06:22 PM |
Demon Tweeks have one at £72. Adjusts to 45deg.
Notcher
Neil
Triton
| posted on 25/9/08 at 03:00 PM |
Tube notchers using holesaws will be a bit hit 'n miss. what you really want is a tube mill using milling cutters. Even then they are damn scary
to use especially on thin guage tube!
I could never justify the daft cost so used the "shed method" mark it out and use a flap disc in a grinder to do it. Easy to make a
template afterwards.
www.tritonraceseats.com
www.hairyhedgehog.com
mr henderson
| posted on 25/9/08 at 04:16 PM |
Notcher
Neil
Good find, looks good too. Shame about the plus VAT though, it's actually £85. Might well end up getting it though
John
[Edited on 25/9/08 by mr henderson]
