blakep82
posted on 24/9/08 at 10:57 PM |
wanted: vauxhall alternator belt adjuster
anyone know where i might get one like this? kind find anything similar for decent money. SBD seemed to want like 50 squid...
[Edited on 24/9/08 by blakep82]
________________________
SeaBass
posted on 25/9/08 at 07:32 AM |
Two rod ends. A piece of Hex bar. A friend with a lathe.
Looks pretty simple. Not sure the alternator is very well supported in that install though?
[Edited on 25/9/08 by SeaBass]
tomgregory2000
posted on 25/9/08 at 08:19 AM |
i used a small s/s rigging screw about 5mm, cut the ends off and weld on a bit of s/s tube to the end on the alt and i cant rember what i put on the
other end but it works beacause of the left and right hand thread and it has locking nuts fitted to stop it coming loose, cost was bout £10
http://www.bainbridgemarine.co.uk/content/default.asp?PageId=367&CategoryId=104&ProductId=451
something like this
tommy
loggyboy
posted on 25/9/08 at 08:28 AM |
Does it need to be that posh?
The standard adjuster from vauxhall is £17!
Mistral Motorsport
blakep82
posted on 25/9/08 at 05:16 PM |
haven't got a lathe, and the only guy i know who has hasn't got the left hand tap i'd need. be easier to buy one really.
loggyboy, it doesn't have to be that posh (nice if it is though) the standard adjuster for my engine is on the power steering pump, which i
ditched.
tommy, i had been looking at those, although the smallest ones are too long for what i need
i think i know what i'll do for now, i found some really thin tube, if i can find a 8mm left hand thread nut (lol, i know...) and a normal one
and weld them on, that will do the trick.
tomgregory2000
posted on 25/9/08 at 05:53 PM |
good luck
tommy
loggyboy
posted on 25/9/08 at 08:40 PM |
ditched.
Yeah, my XE was the same (came from a late Cav SRi) and the inlets are different as the bolt comes is vertical, rather than the normal horizontal, so
i had a nose thru the EPC and found one that suited.
Part no is 90323607 (70 amp alt) or 90409833 (for 90amp) there are more bolts and washers and things to but im sure the parts guy at Vaux can look
them up. (under Cav/vectra A, c20xe, Alternator fittings)
Mistral Motorsport
philfingers
posted on 1/2/15 at 12:56 PM |
I know this thread is ancient but I make this sort of thing
http://pages.ebay.com/link/?nav=item.view&alt=web&id=281563215865
I don't have any listed at the moment but will again in a day or two if any one is interested!
Specials not a problem either
Phil
The true home of cars born under the Sylva name - http://jpsc.org.uk/forum
STM Phoenix R1
Sold-Sylva Striker 1300xf, 40s etc
Sold-Sylva Phoenix, 1300xf, BVH, 234cam, 2xDCOE 40s, live axle - 'old school', rally car and a few bikes
