<<  1    2  >>
Author: Subject: when it comes to bike engines,is bigger better?
austin man
posted on 27/8/12 at 09:25 PM Reply With Quote
Originally posted by OX
Originally posted by Nick DV
.................... and no when your conrod makes an appearance through the side of the engine .
And for what reason did that happen?
Cheers, Nick
Big end bolt snapped 8 laps into a track day at Anglesey
remember the Anglessy mishap made a fair old mess of the block, If I recall hadnt you just had the lump rebuilt
[img] Description
[/img]
[img] warped piston
warped piston
[/img]
Also broke a bailey morris prop shaft but i put that down to constant abuse :-)
[Edited on 27/8/12 by OX]
OX
posted on 27/8/12 at 11:21 PM Reply With Quote
yeah i did it, but only for the gearbox . After it happened i went through the rebuild again in my head to see if anything i'd done might of caused it and couldn't rest until i'd stripped it . I hadn't touched the conrods and the mains were good which i was glad about because that's what i thought,if anything, was what i'd messed up :-) It had lasted 6 months of abuse between engine rebuild and getting towed back to the pits by the tractor of shame
[Edited on 28/8/12 by OX]
zilspeed
posted on 28/8/12 at 05:28 PM Reply With Quote
A gearbox upgrade would get my vote too.
As standard, a type 9 is a woeful thing with terrible gaps between the ratios.
6th on a Caterham box is a direct top, every other ratio is stacked close in between.
daniel mason
posted on 28/8/12 at 05:33 PM Reply With Quote
yeah everyone says the caterham box is superb but a £3k plus its out of budget at the moment. im working on a few things so will let you all know in good time. had some very useful info this week which has put me in the picture with all possible hidden costs!
INDY BIRD
posted on 28/8/12 at 05:46 PM Reply With Quote
I have seems 6 speed boxes about 1500 for recon box I'll keep an eye out,
Good luck
franky
posted on 28/8/12 at 05:58 PM Reply With Quote
also think, is it all going to be worth it?
<<  1    2  >>
