flak monkey
posted on 19/3/07 at 06:16 PM |
I have the 25mm^2 cable on my 2 litre pinto ad the main earth, then from the same point on the chassis a single earth braid from halfrauds. The cable
ratings are for continuous draw. Also the std pinto positive starter motor cable is smaller than 25mm^2 (think its 16 or 20).
Mine works perfectly well. Didnt have a problem when I was cranking it trying to get it to start for the first time. No smoke, hot wires or anything
like that.
I would suggest the simplest of things (like me):
Make sure your earth points are clean, bare metal. Might be worth disconnecting them and checking. Once they are clean and working put a dollop of
vaseline or water proof grease on them to stop them corroding.
If your starter motor is still questionable, i would attempt to try another one.
This is why i fitted an electric fuel pump, you dont need to crank the engine over to get fuel to the engine. Dad started mine up after 6 weeks of
standing, and it fired up as soon as the start button was pressed. Can you tip some fuel in the carb bowls or take the pipe off the pump and draw some
petrol through and prime the system manually. Take the plugs out so there is less resistance in the engine while cranking etc?
[Edited on 19/3/07 by flak monkey]
Sera
http://www.motosera.com
posted on 19/3/07 at 07:53 PM |
simple test, put a jump lead between the negative terminal of the battery and the lifting eye on the engine, should sort it if its a poor earth.
If you need to suck fuel through and its a mechanical pump, try removing the spark plugs (and coil lead!) to make it easier for the starter to turn
the engine.
Balls, need to read page 3 before posting!
[Edited on 19/3/07 by JoelP]
posted on 19/3/07 at 07:55 PM |
Check your timing again if it's slowing the starter down. It sounds like you might have a lot of advance. Does it sound as if it's turning
a few times and then locking and struggling? Is the thin wire from your ignition to the solenoid getting very hot as well?
[Edited on 19/3/07 by Peteff]
TangoMan
posted on 19/3/07 at 11:07 PM |
quote: Originally posted by TangoMan
I would think 3 10mm earth leads should be plenty (and then some!!)
Have you checked the starter motor. It could be that you have a short under cranking which sends much of your power straight to earth. This would
explain a quickly discharging battery and the smoking cables.
I am not sure what current your starter should draw but it may be worth testing it.
If you have a set of jump leads, try connecting them both from battery negative to engine or one from body to engine and one from battery earth to
engine. This will verify if your earth leads are the problem.
Edited 'cos Dave Jenkins post came in while I was typing. If the starter is OK then look elsewhere. Timing/ Very tight engine etc.
[Edited on 19/3/07 by TangoMan]
It's the battery earth lead that smokes, only one of those. Three engine earth's will be more than enough as you say.
So now I am confused. But that's not unusual
Ditchlewis,
Where to the 3 earth leads connect to/from?? For starting you need power and earth between battery and engine. Do you have a lead directly between
battery negative and engine? If this is the smoking one then try two. I still suspect starter though!!
As said earlier, try the jump lead test and then you will know what you are up against.
Summer's here!!!!
Mr G
posted on 22/3/07 at 09:51 PM |
Only if it's 16 or older (18 in October)
