quinnj3
posted on 2/9/08 at 06:51 PM |
oxy is definately the way to go. The nut will come off remarkably easy. May be worth the investment or else take the car to a local engineering
place to get it loosened as previously said and drive it home.
my aim is to build my own locost wether it takes me a week or 10 years to get started, i'm sure i will sometime
Benzine
posted on 2/9/08 at 07:06 PM |
if it accessible, then drill small holes into the nut to try to split it so it releases grip, then breaker bar - may work out the cheaper option.
I just got some drill bits from town. A 2mm metal drill went through it like butter! So I made 6 holes round it. I've been applying penetrating
spray over the last few days (how does that stuff work btw?)
I'll try the air impact gun in the morning (neighbours have a new baby so won't try now)
Can someone tell me more about oxy-acet? Is it used primarily for welding? Is there a "mini" setup I could get that isn't massive
and expensive?
thanks for all the help so far!
mr henderson
posted on 2/9/08 at 07:14 PM |
Have you tried stitch drilling a row of holes on one of the six faces (from front to back) and then whacking it with a cold chisel?
John
car builder
HI mate, where abouts are you? iam used to undoing tight bolts as i work for JCB? i have a big 3/4 inch breaker bar and a 400 foot pound snap on bolt
gun, iam in leicester if i can be any help,
Benzine
posted on 2/9/08 at 07:19 PM |
not yet, I got a cold chisel set in town when I got the drill bits, will try it tomorrow morning
I'm in waltham (right near melton mowbray) With the breaker bar the access isn't that good as I can't get it parallel to the ground
to stand on it, only quite high (like 11 o'clock on a clock face) so an air gun would be best (loads of room for one) are you in the city?
[Edited on 2/9/08 by Benzine]
posted on 2/9/08 at 07:21 PM |
Starter motor is the normal trade way of doing it.
Benzine
posted on 2/9/08 at 07:23 PM |
I tried that, doesn't have enough oomph T_T
car builder
posted on 2/9/08 at 07:29 PM |
iam in narborough. i can pop out may be friday night or sunday night if u are still struggling.
Benzine
posted on 2/9/08 at 07:46 PM |
thanks that's very generous I may be in touch then if I can't shift it in the next few days !
car builder
posted on 2/9/08 at 07:52 PM |
no problem, just let me know how u get on.
mr henderson
posted on 2/9/08 at 08:35 PM |
Is this a 960 engine? I'd be interested to know how the whole project goes because I have an M reg 960 estate 24V which might possibly end up
that way.
John
Benzine
posted on 2/9/08 at 08:45 PM |
that way.
John
Yeah it's the very same!
Michael
posted on 2/9/08 at 09:01 PM |
Chock wheels, stick it in fourth with breaker and long pole.
Works wonders on the rear hub nuts on the old shape beetle.
Benzine
posted on 2/9/08 at 09:58 PM |
Good idea...
...although I have no propshaft yet
posted on 2/9/08 at 10:00 PM |
Usually dosen't work on crankshaft nuts because of the springyness in the engine mounts and drive train.
Only way to hold an engine firmly enough is to remove the starter and lock the flywheel ring gear with a big tyre lever or proper locking tool.
However the starter method always works provided the power bar isn't jammed too tightly against the chassis ie has enough motion to make an
impact to shock the nut/bolt loose.
posted on 2/9/08 at 10:02 PM |
Just a thought --- has it got a locking tab ?
Benzine
posted on 2/9/08 at 10:04 PM |
No it hasn't
ahh, I had it resting against the chassis to begin with. Is the idea to let it move before coming into contact with the chassis to give it a
'run up'?
posted on 3/9/08 at 02:48 PM |
I am assuming you can only get to the nut from the front?
the idea is to drill a hole them enlarge it until it is just about to touch the thread - this should casue it to loosen its grip, or allow a cold
chisel in to to split it.
If you are keen, then drilling another hole opposite should split it- should be no need for more holes than that.
NS Dev
posted on 5/9/08 at 02:28 PM |
quote: Originally posted by MikeRJ
quote: Originally posted by martyn_16v
I've not found anything on a car I couldn't get off if I had enough room to get a 1m breaker bar on it
Only one thing ever defeated me...and it was the crank pulley bolt on my Astra GTE (20XE). Broke two sockets and after buying a decent one I broke my
Britool breaker bar and never budged it.
Yep, the bolts in this thread are mere childs play compared to the XE crank bolt!!!!!!!!!!
"Hold the crank still" hmmmmmmmm
I locked it to the chassis in my autograss car with a 1m long bar welded to a machined ring bolted to the 6 front pulley bolts.................it bent
the chassis, and the bar.
It needed 350ftlb to undo it................
Forget oil, heat, chisels or any other crap, you need to holt the crank still with a proper tool, then borrow a BIG truck wheelnut gun, at least
3/4" drive, set it to max reverse torque, and that should crack it.
Benzine
posted on 7/9/08 at 05:48 PM |
Here's the dirty little fecker!
A million thanks to car builder for coming over with his snap on electric impact wrench. What a bit of kit!
