Author: Subject: wanted bosch distributor plug for pinto
ragindave
posted on 12/11/08 at 08:53 AM Reply With Quote
I need the one in the picture with the red and yellow wires I only need the male part as the female plug is ok.
Any one got one, beer tokens at the ready.
Thasank you.
mcerd1
posted on 12/11/08 at 08:58 AM Reply With Quote
I'll have a look
I should have a couple - if its the same on an EFI granada
what length of wire would you like ?
ragindave
posted on 12/11/08 at 09:19 AM Reply With Quote
Longer the better thank you
gavin174
posted on 12/11/08 at 10:59 AM Reply With Quote
why not cut the plug off and solder straight through..
you can always remove the little plug from the dizzy if you need to rake the dizzy out
DarrenW
posted on 12/11/08 at 12:14 PM Reply With Quote
I just used spade connectors straight onto the terminals. Also used small cable tie to secure the wires.
mcerd1
posted on 15/11/08 at 03:41 PM Reply With Quote
I've had a good look at all my ones now
I have got bosch distributors, but they must all be a later type than yours as they are nothing like that pic (mine have 3 wires and a different plug)
so sorry about that - I guess you cut off the old plug and fit a new one of any type you like
[Edited on 15/11/08 by mcerd1]
ragindave
posted on 19/11/08 at 09:02 AM Reply With Quote
Thanks for looking I am still after one if anyone can help
