jamie1107
| posted on 12/11/08 at 02:04 PM |
Wanted sierra steering columb and body work
hi guys
im looking for a sierra steering columb wth switches key wheel covers etc if possible id really like an adjustable one but its no big problem if its
not
i could also do with the steering down link and some body work i need the whole lot nose cone bonnet wings etc for a locost preferably in the south uk
in order to pick the bodywork up
thanks
james
wilkingj
| posted on 12/11/08 at 02:18 PM |
Jamie,
Put your approximate Location in your profile. Then it show up on every message.
It does help people when looking to see if they can help.
There are a couple of Sierra's in the scrapyard between Cambridge and Newmarket, and they had the sterring columns in them. That was about 3
weeks ago.
Dont know if that helps.
Best Regards
Geoff
http://www.v8viento.co.uk
dubstar_04
| posted on 15/11/08 at 01:44 PM |
Whats the going rate for a sierra steering column?
Also Is the ignition key required?
jamie1107
| posted on 17/11/08 at 03:16 PM |
thanks guys ur right about the profile i should have put that in yonks ago
im not sure what the going rate but an ignition key would definatly be needed otherwise you have no imobalisation divice for the sva
unfortunatly scrap yards are a bit awkward cause im in a chair while i recover from a bike accident so was hoping to source the bits off the car even
if it costs a little more
