chris_smith
| posted on 23/11/08 at 07:57 PM |
WTD - crossflow alternator
as above really for a 1300 x flow the one i have seems to be for the opposite side im assuming they had 2 engine configerations?
or am i just completely stupid!
regards
chris
| posted on 23/11/08 at 08:06 PM |
IIRC you should be able to remove the alternator body screws and rotate the two casings to the alignment you need. If not one from a classic Mini will
be the same.
cjtheman
| posted on 23/11/08 at 10:07 PM |
yes same as above
cheers
colin
| posted on 24/11/08 at 09:53 AM |
^^^ yes - what he said. It will be Lucas type on which there are 2 or 3 very long bolts; undo and then rotate so the lugs are in the required
orientation.
Syd Bridge
| posted on 24/11/08 at 11:02 AM |
Minispares are doing a good deal on new alternators. Also been quoted good prices at Partco lately.
Syd.
chris_smith
| posted on 24/11/08 at 09:34 PM |
ok it has 4 long bolts which i removed today only to find once i rotate the end that it doesnt line up do i have the right alternator sorry no pics
