Author: Subject: Escort clutch release arm
posted on 29/11/08 at 05:47 PM Reply With Quote
for a Mk1/2 aluminum bell housing. My Sierra item just doesn't fit
Got one lying around you can part with?
Thanks,
trextr7monkey
posted on 29/11/08 at 08:25 PM Reply With Quote
Hi Steve, if it is same as bog standard 4 speed jobby we should have one- is it urgent or something to drop off next trip over - [13th December I think.]
Did you get an SJ ?Jago?
Also did you flog your trailer ? if not send us a pic
atb
Mike
posted on 29/11/08 at 08:38 PM Reply With Quote
Hello Mike, not sure about them as all I know ATM is the Sierra one fouls the ali bell housing.
Still got the trailer and if you want to call in I'll show you why I haven't got a Jago yet
24vseven
posted on 29/11/08 at 10:32 PM Reply With Quote
hi, if its the rs2000 alloy bellhouseing then niether the standered escort 4 speed one fits or the sierra one you need to either find the correct rs part or modify the sierra one by straightening the line from the relese bearing mount to where the cable fits efectivly narrowing it at the point where it fits through the bellhouseing
posted on 30/11/08 at 10:49 AM Reply With Quote
Seconded, I modded mine a couple of years ago , can't remember exactly how but it was fairly obvious at the time.
