Author: Subject: Megasquirt bits
flak monkey
posted on 16/12/08 at 02:51 PM Reply With Quote
Megasquirt bits
I need an air intake temp sensor and coolant temp sensor for my megasquirt....
Any one got some laying about?
Pennies waiting
Sera
http://www.motosera.com
phoenix70
posted on 16/12/08 at 04:20 PM Reply With Quote
Can't help you with the sensors, but I'm using the standard for water temp sensor on my MS install, and bought an air temp sensor from phil at ExtraEFI.
Scott
PS. let me know how you get on with your MS install, I'm in the middle of mine atm.
omega0684
posted on 16/12/08 at 04:28 PM Reply With Quote
i got air and water temp sensors from phil @ extra efi, cost me £40.
Myke 2463
posted on 16/12/08 at 05:01 PM Reply With Quote
Inlet Temp sensor.
Hi Dave, mondeo inlet manifold temp sensor any good ? in Lynn next monday shopping, could meet.
Mike.
flak monkey
posted on 16/12/08 at 05:02 PM Reply With Quote
Scott
Thanks Scott, will keep you updated.
I can't use the standard temp sensor as I have replaced it with a thermocouple to interface with my Aim dashboard.
Sera
paulf
posted on 16/12/08 at 08:38 PM Reply With Quote
Rs component sell a bead type thermistor of the correct range to use without having to use easytherm, unfortunately I cant remember the part number at the moment though..I used one for the air temperature and used a bosch coolant sensor from a peugot for the water temp.The water one is a few degrees out but as it only controls warm up is not so important, the air temp needs to be as near as posible as it directly controls mixture at all running temperatures.
Paul.
Snuggs
posted on 16/12/08 at 09:10 PM Reply With Quote
I am going to use 2 of these
http://cgi.ebay.co.uk/Vauxhall-VECTRA-CALIBRA-TIGRA-WATER-TEMP-SENDER-NEW_W0QQitemZ370103612367QQihZ024QQcategoryZ10404QQcmdZViewItemQQ_trksidZp1742.m 153.l1262
A coolant temp sensor can be used as an air temp sensor but not the other way round.
Connector is the same as injector connector (I think)
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
