locosaki
posted on 17/1/09 at 06:50 PM |
Induction help
I'm currently using the orginal airbox,I've turned it upside down and altered it to suit the bec installation,I've bored a 4"
hole in one side and fitted a cone filter as I had 1 lying around,Anyone got any better suggestions on getting the indution right,I can't get
away with the sausage filter through the bonnet as these carbs are side draught carbs.
Here is a pic of what i have done
http://s439.photobucket.com/albums/qq117/locosaki/?actio
Daimo_45
posted on 17/1/09 at 07:33 PM |
I would personally run an enclosed induction kit from the airbox all the way to a cut-out on the bodywork like this:
Or better still, replace the original panel filter inside the airbox with a high flow K&N panel filter and then just run a feed to a cut-out on
the bodywork.
Omni
posted on 17/1/09 at 08:36 PM |
How much is that?
O
Daimo_45
posted on 18/1/09 at 03:08 AM |
A lot. Circa £200.
