Krismc
| posted on 31/1/09 at 06:38 PM |
Sierra steering rack lock nuts
im after some Steering rack lock nuts for a sierra??!
Does any one have any spare or can tell me the size so i can order some, or the part number as ford cant find them on there system.
im guessing they are M14 ish
A1
| posted on 31/1/09 at 06:39 PM |
i used m12x75mm bolts with nylocs on mine...would probably be good to use some threadlock too, then itll never come off
cloudy
| posted on 31/1/09 at 06:42 PM |
I think it's bigger than M12? may be wrong...
I'm also interested - it needs half nuts really...
www.warnercars.com
DanP
| posted on 31/1/09 at 06:43 PM |
I have a load of M14 (i think) half nuts that i used for my escort mkii rack if these are any use.
Send me your address if you want a few and I'll post you a couple.
HTH,
Dan
lotusmadandy
| posted on 31/1/09 at 06:45 PM |
I used a pair of m14 nylock nuts
on mine but filled off the nylon.
Krismc
| posted on 31/1/09 at 06:59 PM |
Definatly needs the half/Lock nuts on a MNR RT Plus, as there is a steering rack extension fitted between rack and rod end, i need the lock nuts to
lock of the extension piece as it can easily be turned by hand- nut sure why they are half nuts, but thats what i was told i needed but just cant get
any!?!
