AdrianH
| posted on 8/2/09 at 08:17 PM |
Is there such a thing as a 22 x 1.5mm radiator pipe adapter?
I am using a Renault radiator in my car and want to use the hole meant for the fan switch as an inlet for the expansion tank.
Is there such a thing before I try and make one, I will struggle with the 22 mm thread.
Adrian
Why do I have to make the tools to finish the job? More time then money.
stevebubs
| posted on 8/2/09 at 08:24 PM |
Get a 22mm x 1.5mm blanking plug and then drill/tap it for whatever adapter you want?
AdrianH
| posted on 9/2/09 at 07:34 AM |
Hi Steve thanks for the idea, are all the sizes the same for the blanking plug as not finding any on the bay that lists them by thread.
Adrian
Krismc
| posted on 9/2/09 at 08:58 PM |
plenty off the shelf at my local PIPELINE center
cosworthspeed10
| posted on 10/2/09 at 05:18 PM |
Try these
http://www.airlink-compressors.co.uk/Fittings/plugs.htm#BLANKING%20PLUG%20M%20METRIC%20O%20STEEL
