Author: Subject: GSXR 750 or 1000 throttle bodies
flak monkey
posted on 2/3/09 at 07:18 PM Reply With Quote
The seperate ones which can be re-spaced (not sure which series that is?)
Also looking for a set of head flanges from the bike (the bits the throttle bodies are attached to...)
Sera
http://www.motosera.com
will121
posted on 2/3/09 at 08:55 PM Reply With Quote
gsxr K1, k2 and k3 can be split, think 600's are 38mm, 750 are 42mm dont know about 1000's ive got a set of gsxr750Y which look the same as the K1 but apearable not to come apart however look could be splitable by cutting the linking part and spacing. the mounting flanges seem to be called inlet rubbers
matt_claydon
posted on 2/3/09 at 10:11 PM Reply With Quote
Like this (GSXR 750 K1)?
Bodies mounted to manifold
Already re-spaced so comes with the threaded bars and nuts, the rail joiners cut and extended with injection hose and also with a second fuel rail inlet/outlet (cost £17 from Suzuki) so you have a proper 'flow through' rail.
Can include four short bits of 48mm fuel hose and the rubber trumpets (cost me £15) too if necessary. Manifold is Pinto so unfortunately not much use to you though.
Special LB price: £100 + delivery if you're interested.
[Edited on 2/3/09 by matt_claydon]
flak monkey
posted on 3/3/09 at 07:54 AM Reply With Quote
Hi Matt,
You have U2U
Sera
