Author: Subject: edis 4 unit
flak monkey
posted on 8/3/09 at 05:52 PM Reply With Quote
edis 4 unit
Anyone got an edis 4 module spare? Preferably with a plug and short bit of wire too...
Sera
http://www.motosera.com
Myke 2463
posted on 8/3/09 at 07:42 PM Reply With Quote
Hi Dave.
Try big_wasa in Spalding, normally has several.
Also 1st for ford @ Tilney St. Lawrence.
mike
[Edited on 8/3/09 by Myke 2463]
big_wasa
posted on 8/3/09 at 08:52 PM Reply With Quote
Lol ive run out
I can sort you a plug if you need it i think.
cheers
James
posted on 8/3/09 at 09:47 PM Reply With Quote
Flak,
You going to keep the EDIS 4 rather than fitting exta coil drivers to your MS?
I've been trying to decide on this myself. I like the idea of the 'limp-home mode' of having the EDIS 4 (and some have said the coil drivers are unreliable too) but I also like the idea of being more 'efficient' by not using the EDIS4!
James
flak monkey
posted on 8/3/09 at 10:01 PM Reply With Quote
My MS already has coil drivers built in, but I have heard that they havent been that reliable so I thought I would go the edis route as, like you say, it also gives you the benefit of limp home mode.
Sera
omega 24 v6
posted on 8/3/09 at 10:10 PM Reply With Quote
Depends on which ones you have David.
If you have the new bosch BIP units they are I'm told pretty indestructable. They have a built in thermal overload so if you get your dwell setting wrong they just overheat and the reset. I have them now but my original vb 921's were fried when i for some reason made the dwell to long.
flak monkey
posted on 8/3/09 at 10:18 PM Reply With Quote
Yep, mine are the VB's
Theres less to set up with the edis too isnt there?
Sera
omega 24 v6
posted on 8/3/09 at 10:20 PM Reply With Quote
Sorry I don't know. I was using the v/hall engine so never had access to the edis units. many folk do swear by it as it has a limp home mode which will get you back if the squirt side of it fails.
I presume this means the fuel mapping is as good as finished and you've now decided to go MSNS Extra
[Edited on 8/3/09 by omega 24 v6]
flak monkey
posted on 9/3/09 at 08:04 AM Reply With Quote
Its for the duratec when I get that far
Fuel mapping on the pinto is nearly complete though.
Sera
