Poll: Fuel Delivery [View Results]
Twin SU
Triple SU
Standard EFI
Megasquirt
Author: Subject: Fuel Delivery
speedyxjs
posted on 13/3/09 at 03:38 PM Reply With Quote
Fuel Delivery
Im still undecided as to what fuel delivery system to use.
A rough idea of cost of megasquirt would also be helpful.
Engine is 3.6 AJ6
Vote NOW!
flak monkey
posted on 13/3/09 at 03:41 PM Reply With Quote
Megasquirt.
Will probably cost around £400 inc throttle bodies etc to fit. As long as you can make your own manifold of course.
Either that or it has to be triple webers
Sera
http://www.motosera.com
speedyxjs
posted on 13/3/09 at 03:43 PM Reply With Quote
Yeah, i thought about that but £700 is a bit ott imo
owelly
posted on 13/3/09 at 03:52 PM Reply With Quote
I have a bank of three carbotooters off an outboard engine. They're big!! Probably big enough to tandem two pots per carb or get another set of matching carbs. No-one has cottened on to these carbs yet so grab them before they do!!!
http://www.ppcmag.co.uk
mark chandler
posted on 13/3/09 at 04:59 PM Reply With Quote
Two lots of triumph trident TB's or cut some scabby carbs up and mount the butterfiles on the original manifold and use standard injectors. MS away you go.
Daimo_45
posted on 13/3/09 at 07:21 PM Reply With Quote
3.6 guzzler will need this
speedyxjs
posted on 13/3/09 at 07:50 PM Reply With Quote
Well, thats already pretty conclusive. Thanks guys.
