| posted on 25/3/09 at 11:29 AM |
wanted - M8 wire crimp on lug
like these:
Only need one to connect MIG earth to calmp. Note sure what wire size is.
I know VWP sell them but postage is a fiver plus delay so I am trying to avoid that route.
Anybody got one going spare? (I may have one at home but not sure, sod's law it'll be wrong size :mad . Or where to buy on high street?
dan__wright
| posted on 25/3/09 at 11:31 AM |
ive got some, possibly m6 though (will check when i get home) but could probably be drilled to m8.
can pop 1 in the post if needed.
Richard Quinn
| posted on 25/3/09 at 12:15 PM |
Probably. What wire size?
madrallysport
| posted on 25/3/09 at 01:00 PM |
u2u me your address, i have some i'll pop them in the post to you
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
PaulBuz
| posted on 25/3/09 at 04:16 PM |
As alraedy stated they come in 6mm or 10mm wire size.
also what diameter hole do you need?
Paul
| posted on 26/3/09 at 08:07 AM |
thanks for offers - hole is 8 mm - clue is post title!
I wasn't able to measure wire diameter (or work out cross section) - it is clarke MIG 120 (about 20 yrs old eek!!!?!?)
OI don;t wanbt folks sending me stuff that may not fit and I need it for the weekend; also I may have one as I bought a small selection but again did
not look.
I may get away with a copper pipe but hopefully measure up tonight.
| posted on 27/3/09 at 08:26 AM |
I did some measuring - the cbale od (inc insulaiton is 7 mm) so I am guessing 4 mm diameter, allowing for 1.5 mm insulation.
on the cable itself it states 10 mm 2 - this works out to be 3.6 mm diameter; seems quite thin to me.
I am gonna have a go making my own from some 10 mm copper clutch pipe and see how that goes since time is of the essence, else whoever has one for hte
above then I can pay paypal.
ta.
summary
8 mm hole for 10 mm2 wire (approx 4 mm dia.)
mad-butcher
| posted on 27/3/09 at 11:50 AM |
do it the locost way strip about an inch or so of the insulation then put it inside a piece of 15 mm copper tube flatten tube then drill a hole
tony
