saigonij
posted on 27/3/09 at 12:12 PM |
Can you still book an SVA test?
Is it still possible to book an SVA test or has the cut off already been reached?
blakep82
posted on 27/3/09 at 12:20 PM |
i think the booking date was supposed to be 20th march for tests by the end of april? not heard anythink about any more extentions, but i don't
think you can buy the IVA manual yet though
[Edited on 27/3/09 by blakep82]
________________________
FEZ1025
posted on 27/3/09 at 12:42 PM |
Somebody on our forum got a call from VOSA yesterday stating they were refusing to sort his SVA as they had received the paperwork too late & he
would have to go IVA. However when he asked to change it to IVA they refused as they didn't know how much it was & how to actually book a
test.
Alan...
Madinventions
posted on 27/3/09 at 12:49 PM |
AFAIK, all SVA applications had to be received by 28th Feb. SVA tests will continue to be run until the end of April.
If you apply now, it'll have to be for an IVA.
Like the bloke said at my SVA - "If you've built the car properly, you won't have a problem." It's just the cost of
IVA...
![](/images//smilies/sad.gif)
matt_gsxr
posted on 27/3/09 at 01:40 PM |
IVA...
Not 100% fair. The SVA test is part of a specification when designing a vehicle. Changing the specification during a project is not a good idea.
I would cite "reverse gear on a BEC".
A pass under SVA, a fail under IVA.
Matt
myke pocock
posted on 27/3/09 at 02:28 PM |
Andrew in carisle VOSA showed me the latest News Letter and it says £450 and £90 for a re-test so VOSA head office should know by now! There are some
detail changes such as the need to tether the filler cap to the bodywork OR use the same key as the ignition to lock it. Also at the moment in the
footwell anything over 150mm from the floorpan is checked for sharp edge. IVA says all shoud be so does that inclue peddle boxes? Some may fail if it
does. Worth checking. To me saying that if you have done it right it should get through may not be all the story as it is so easy to miss a critical
bit even though you do it right and to a good quality. Talk to the tester is, I think, the best option if you have problems. I did this with my seat
belt mounting arrangement and passed OK due to Andrews advice.
