Author: Subject: aero fuel filler cap.
stuleah
posted on 7/4/09 at 05:00 PM Reply With Quote
anybody got a locking aero fuel filler cap or know where i can get one for a good price need to be minimum 95mm o/d preferably with funnel neck .
cheers
[Edited on 7/4/09 by stuleah]
andrew-theasby
posted on 7/4/09 at 08:47 PM Reply With Quote
Hi, just wondering if your asking this due to the iva rules, thinking that a non locking one may not pass. An examiner explained to me a few days ago that it just needs to be secured basically so you cant drive off without it. Which means to pass using the key as the securing method it must be the same as the ignition key. If its just for security, then a different key is ok, but it must be held on by a tether. And just on a different note, it cant be mounted on a surface which could overflow into the cockpit area ie most "boot lids" Sorry if you knew this already, just thought if you were replacing a non locking one, its not necessary for the test. HTH
stuleah
posted on 7/4/09 at 09:39 PM Reply With Quote
cheers for the info, i didnt know that. i am not actually replacing one i just need to get one as i have nothing.
thanks
andrew-theasby
posted on 7/4/09 at 09:46 PM Reply With Quote
No prob, just need to tether it then., hope you get one.
