Author: Subject: Header tank needed with 12mm bottom hose connector
Jasper
posted on 30/4/09 at 01:51 PM Reply With Quote
Turns out the heeader tank I've got is no good, the bottom hose is to small a bore ar 8mm, I need more like 12mm.
Now I could probably get it adapted, but I'm on a time constraint so I can drive it to SVA retest next week without the hassle of getting hold of a trailer again.
So has anybody got a header tank with a large bottom connector and small top connector?
A loan one would do as the guys who made up my ali one will adapt it for me.
[Edited on 30/4/09 by Jasper]
Miks15
posted on 30/4/09 at 02:07 PM Reply With Quote
http://cgi.ebay.co.uk/Metal-Fuel-Hose-Joiner-Connector-Reducer-12mm-8mm_W0QQitemZ120411803360QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM ?hash=item120411803360&_trksid=p3286.c0.m14&_trkparms=72%3A1683%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50< br />
Mabye somthing like this?
[Edited on 30/4/09 by Miks15]
Jasper
posted on 30/4/09 at 02:22 PM Reply With Quote
No good, as it still restricts the input into the tank to 8mm....
contaminated
posted on 30/4/09 at 02:26 PM Reply With Quote
I've got a polo one knocking about somewhere. I'll check the dimensions later, but I think it's about right.
Jasper
posted on 30/4/09 at 02:35 PM Reply With Quote
Cheers - hold off for a sec as I may be able to get my existing tank altered by a local engineers I've been put onto.
COREdevelopments
posted on 30/4/09 at 05:37 PM Reply With Quote
i have used a reno clio one (2000 on) cheap and plentyfull. also pretty sure its 12 mm as i had same problem as you, its got a smaller top pipe too.
Rob
