Author: Subject: DESPERATELY WANTED lol!!! Clutch arm
prawnabie
posted on 28/7/09 at 10:35 PM Reply With Quote
Hi
I need a clutch arm for a type 9 before the weekend - anybody got one they can post special delivery for a chap in need? Muchas beer tokens waiting!!!
This is the shape I need!!
Shaun
gavin174
posted on 28/7/09 at 10:45 PM Reply With Quote
u have u2u
gavin174
posted on 28/7/09 at 10:56 PM Reply With Quote
trextr7monkey
posted on 28/7/09 at 11:05 PM Reply With Quote
Thought we might have had one but can't see it anywhere obvious, get on the phone to G and S Escorts in Widnes tomorrow am
atb
Mike
prawnabie
posted on 28/7/09 at 11:07 PM Reply With Quote
Think Im sorted now - thanks all!
Dusty
posted on 29/7/09 at 01:20 AM Reply With Quote
You are putting it in the right way round? The pictures above show the surface that faces the release bearing, clutch, flywheel, engine.
posted on 29/7/09 at 08:41 AM Reply With Quote
Yes - check that. Mine (4 speed Ford) had been fitted wrong way round yet it worked!! Only problem I could see was that previously the clutch cable was almost wound fully out.
The release bearing will have 2 spring clips that clip onto the tabs.
I had problem keeping my arm on the pin in the bellhousing - a small piece of neoprene solved that - just enough to keep it in place to allow the release bearing to be fitted - whcih then holds are in place.
