Donners90
posted on 20/3/04 at 02:15 PM |
Sherpa Remote
I'm looking for a gear change remote mechanism originally fitted to a sherpa van with the LT77 box. I need it to replace the SD1 version which
is too long for my chassis!!
If anyone has one lying around or knows where I might be able to find one please can you get in touch?
Many thanks
James
bob
posted on 20/3/04 at 06:15 PM |
the sherpa remote is an old cobra replica builders trick,try some of the cobra sites.
I think they have a very active forum
posted on 20/3/04 at 08:08 PM |
Is a diesel sherpa fitted with an LT 77 box, may possibly know where to get one in the Cambridge area. Let me know , also some of the Jag gearboxes
used an extension that would fit on to a SDi box, fitted one years ago on a Marcos . Rusty
Donners90
posted on 21/3/04 at 01:48 AM |
Cheers Bob,
I know hotrodders use them as well but I hadn't thought about the Cobra lot. I'll try their forums.
Rusty,
As far as I can tell the Sherpa diesels were also fitteed with the LT77, and as such I would be interested in knowing where to get one. Regarding the
Jag boxes, which models had the remotes that would fit the LT77, just so I know what to look out for?
Thank you both for your help
James
posted on 21/3/04 at 07:09 PM |
James, from what I remember remote was from xj6 with something like a 2.8 lt engine , brought new from our local jag dealer because at the time unable
to find used item, may be available now if you can find one, but believe manual jags fairly rare. Rusty
Donners90
posted on 23/3/04 at 12:41 PM |
Found one
Thanks Rusty and Bob,
I managed to pickl one up in a local scrappy.
Thanks for the advice
James
