brianthemagical
| posted on 22/8/09 at 05:00 PM |
32mm ID coolant hose
Hi, time has come to re-do the plumbing, so i'm after some coolant pipe/hose.
It needs to be 32mm ID hose, or 32mm OD solid pipe. Not too sure what i need, definately some 90 bends, so what have you? Flexi hose is also on the
list.
I think it's looking like some bends, and short joiners, so don't be shy and i'll see what i can use.
Thanks y'all.
| posted on 22/8/09 at 05:45 PM |
I splashed out on silicone hose, off ebay.
thermostat is 38->32 mm right andle reducer, water pump is two 90 degree right angle with 32 mm aluminium joiner.
water pump to manifold is 18 mm hose
| posted on 22/8/09 at 05:47 PM |
and from another angle...
turbodisplay
| posted on 22/8/09 at 06:10 PM |
you can get 32mm hose wth a metal spirial built in. you can have a serious bend and the spirial will keep the wall from collapsing.
Darren
brianthemagical
| posted on 23/8/09 at 08:14 PM |
Thanks for the help peeps.
I've had a mooch round, and have found many a place selling sutible pipework, but i was more wondering if anyone had any old or secondhand
stuff. Partially to re gain some pennies and to save me some while i perfect the plumbing before shelling out on expensive silcon jobbies.
Thanks again.
