peter bland
posted on 14/10/09 at 12:48 PM |
Gear indicator for bec
has anybody fitted a g.p.t. gear indicator, im having problems setting mine up.
Flamez
posted on 14/10/09 at 04:16 PM |
No sorry mine was a girpro which was plug and play
my build mac1motorsports
motorcycle_mayhem
posted on 14/10/09 at 04:47 PM |
Just under your avatar you mention GSXR.... oh yes...
Apart from having made a great engine choice, there's are several GPI's that plug straight into the loom (white triangular plug) and read
the engine's GP switch (simply, as I'm sure you're aware a selection of resistance values). These GPI's are what you really
need for a GSXR, not the propshaft/speed sensor type.
If it's what you've got, it's faulty....
peter bland
posted on 14/10/09 at 06:14 PM |
the display i have is new with the instructions and picks up the speedo and rev wires in the instrument harness with pos and neg feeds. It has a wire
for programming but when i go through the program it gose from 1st to 3rd and no further. The make is italian and no reply to e-mails ! oh bugger
bob tatt
posted on 14/10/09 at 06:19 PM |
get rid of it and get the gi pro as said plug and play. spent hours trying to get mine working with no joy. wifey got me the gi proo for my birthday
(she does listen some times when im rambeling on about cars) pluged it in done in half hour works a treat
Wells
posted on 15/10/09 at 07:23 PM |
Geartronics. Thats about as good as it gets for a GSXR. Not cheap though!
motorcycle_mayhem
posted on 15/10/09 at 09:07 PM |
I have the Geartronics - GSXR. I can't fault it, lovely.
richard thomas
posted on 17/10/09 at 05:28 PM |
Ditto. Came with timing retard eliminator built in too....
:{THC}:YosamiteSam
posted on 19/10/09 at 05:37 PM |
same here - took minutes to fit - never had a problem with it
geartronics
bowood14
posted on 23/10/09 at 03:45 PM |
what about a 919 fireblade gear indicator
Which unit would people recommend for a 919 fireblade in a MK indy
