blakep82
| posted on 19/11/09 at 12:01 PM |
aluminium channel. 70mm x 20mm
anyone got any? or know of a supplier that DEFINITELY has it?
need a piece 80cm long to make this for my radiator mounting
________________________
MK9R
| posted on 19/11/09 at 12:25 PM |
what about using box and cutting it
box section
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Dingz
| posted on 19/11/09 at 01:53 PM |
Usually available in imperial sizes, so 3 x 1 would be a stock size or 2 1/2 x 1 ?
went on and on.
blakep82
| posted on 19/11/09 at 03:03 PM |
hmm, might have to look at steel then...
what sort of thickness should i make this out of then do we think?
its to go where the bit of wood is in this photo
to sort this problem
1.5mm? could it be thinner? i'll probably need a thickness that i can fold easily enough with some bits of wood and a hammer/mallet
[Edited on 19/11/09 by blakep82]
andyw7de
| posted on 19/11/09 at 03:09 PM |
Blake,
Ive got some 1mm wall 50 x 20 Ali box at lease i think its 50, may be 40 I'll check is its any good to you.
cheers
andyw7de
| posted on 19/11/09 at 03:14 PM |
just checked
38 x 19 (1 1/2 inches x 3/4)
blakep82
| posted on 19/11/09 at 03:22 PM |
cheers Andy. might be a bit too narrow though i think. would maybe be happy 2" (70mm is 2.75" ) and the remaining 0.75" might need a
spacer to stop it rattling in the channel. i plan to put a bolt through it somewhere to bolt to the steel channel in the chassis though
cjtheman
| posted on 22/11/09 at 06:48 PM |
you have u2u
cheers
colin
wanted
sunny weather
sva pass 12/6/09
taxed 16/6/09
