Author: Subject: Throttle position sensor
flak monkey
posted on 14/1/10 at 08:20 PM Reply With Quote
I am in need of a throttle position sensor to fit onto a shaft with 2 flats on it.
Anyone know of anything which is a standard fit component on a production car? Or inded where I could get one from otherwise? I have found the sensors with a male shaft, but no female ones.
Thanks,
Sera
http://www.motosera.com
turbodisplay
posted on 14/1/10 at 08:42 PM Reply With Quote
ford sensors will work, think escort and cosworth v6, both have said fittings.
Darren
Myke 2463
posted on 14/1/10 at 08:46 PM Reply With Quote
HI Dave, try Dave Walker @ Emerald, he uses female ones, think only 1 flat but not sure.
Mike.
flak monkey
posted on 14/1/10 at 08:55 PM Reply With Quote
Thanks.
ETA it also needs to suit a shaft which rotates clockwise looking at the shaft
As I assume they are directional otherwise they would count the wrong way!
Sera
will121
posted on 14/1/10 at 08:57 PM Reply With Quote
Darren
this is a ford Fiesta/escort one
flak monkey
posted on 14/1/10 at 09:02 PM Reply With Quote
Thanks Will.
That looks like it doesnt turn with the shaft all the time, i.e has some free play in each direction?
Sera
matt_gsxr
posted on 14/1/10 at 09:15 PM Reply With Quote
Normally they are spring loaded. The picture there is very similar (although it looks bigger) than gsxr1000 ones. The spring loading avoids any slack, I think it is one of the standard ways of doing it.
Matt
paulf
posted on 14/1/10 at 09:16 PM Reply With Quote
There spring loaded so the spring takes up the slack, ive used one in the past with no problems but it depends on the direction of rotation that you require.RS Components also do some shaft fitting potentiometers the same as the ones supplied by emerald etc.
Paul
Thanks Will.
flak monkey
posted on 14/1/10 at 09:31 PM Reply With Quote
Thanks, I looked on RS and couldnt see anything suitable. Will look in the catalogs tomorrow though.
I *think* I need one for clockwise shaft rotation, will check it out though.
I could of course get one from caterham, but I bet they are a fortune! Waiting for a mail reply from them too.
Sera
austin man
posted on 14/1/10 at 09:53 PM Reply With Quote
I used the Ford TPS on my twin webbers, I bought some polymorph (a low melting point plastic compound) off the beloved ebay and filled the hole then using a dremmel cut a new slot in the plastic for the webber spindle to sit in
flak monkey
posted on 14/1/10 at 09:54 PM Reply With Quote
Found these on RS website
Clicky
They look suitable, am waiting for a response from someone from RS
[Edited on 14/1/10 by flak monkey]
Sera
r1_pete
posted on 15/1/10 at 07:56 AM Reply With Quote
Thanks.
Just reverse the outer 2 connections to change the direction it reads, Rescued attachment Pot.jpg
flak monkey
posted on 15/1/10 at 11:30 AM Reply With Quote
Originally posted by r1_pete
Thanks.
Simple as that hey? Excellent
Got a price from Caterham, £35 for the proper one to fit. So not too bad really.
Sera
