carpmart
| posted on 25/1/10 at 06:05 PM |
10 Ton Press
Guys
Have any of you got a press (ideally bench top) that is taking up valuable workshop space? I can give it a good home if you have!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
Valtra
| posted on 26/1/10 at 01:10 AM |
U2U
"If it looks like it works and it feels like it works, then it works"
carpmart
| posted on 29/1/10 at 02:48 PM |
Bump
Still want one!
'94 MX5 MK1, 1.8
907
| posted on 29/1/10 at 03:40 PM |
You could make one.
Two bits of thick plate with holes drilled in the corners about 300 x 150mm.
(Or RSJ, PFB, RSC, or whatever you can get hold of.)
Two 1M lengths of studding cut in half, + nuts. (I used M20)
10 tonne bottle jack.
HTH
Paul G
carpmart
| posted on 29/1/10 at 04:25 PM |
quote: Originally posted by 907
You could make one.
HTH
Paul G
Hi Paul
It does help - do you have a picture or two you can share of the finished article? Any plans available?
Thanks!
'94 MX5 MK1, 1.8
907
| posted on 29/1/10 at 05:36 PM |
It started life as a pipe bender.
Like all things Locost it got modded.
The last job it did was to press out the metalistic wish bone bushes on a catering van.
Oooo, those bones ain't half thin, and light.
Paul G
