Author: Subject: Catch Tank - filling up?
Tiger Super Six
posted on 1/3/10 at 02:02 PM Reply With Quote
Chaps,
Took my car out for a blast on Saturday and although the drive was good, when I got back the oil catch tank had about 0.5 litre of oil in it! (onyl did 5 miles). On a previous car, my engines never used to push anything out?
Could it be that I drove it too hard when the oil was cold so it built up too much pressure and pushed it out, or is there another reason do you think?
It's on a pinto and I have the hole under the exhaust headers blanked off and then have a take off from the crank case breather into a T piece that also collects from the rocker cover and then goes into the catch tank.
Any ideas on what caused it, or if there's a problem?
Mark.
Mark
Tiger Avon
nitram38
posted on 1/3/10 at 02:22 PM Reply With Quote
You've blocked the breather so the crankcase is pressurizing.
You need a hose from the top of the engine and the side of the block to end up in a catch tank that is open to the atmosphere, seperately not T.
Originally the block one would have gone into the inlet manifold to create a negative pressure in the block and burn off any oil vapour.
[Edited on 1/3/2010 by nitram38]
Tiger Super Six
posted on 1/3/10 at 02:55 PM Reply With Quote
I had my old engine with the T piece and the catch tank is then vented to the outside via another pipe, so my thought is that both pipes (joined via the t piece) are effectively then vented to the outside?
The only thing I am wondering is that on the crank breather the chap I bought the car from had fitted some kind of wire thing in the pipe that comes off the crank breather, could this be sufficient to pressure the system, I left it in as I assumed he put it there for a reason, but should I take it out?
[Edited on 1/3/10 by Tiger Super Six]
Mark
Tiger Avon
tigerzetec
posted on 1/3/10 at 03:31 PM Reply With Quote
Used to have a T peice on my Zetec. Found it was syphoning. Now have a Hose from the crankcase to the catch tank, but with a pcv valve inline where two hoses join together. The hose from the cam cover goes to a separate filter. Now i don't get loads of oil in the tank when i corner heavy, which was another problem i had.
jacko
posted on 1/3/10 at 08:20 PM Reply With Quote
Originally posted by Tiger Super Six
Chaps,
Mark.
Which hole do you have blocked? do you mean the water pipe coming out the inlet manifold?
You need the breather pipe coming out the block no one way valve to a catch tank and a pipe from your oil filler cap to the catch tank the catch tank wants a small filter on the top
[Edited on 1/3/10 by jacko]
Tiger Super Six
posted on 1/3/10 at 10:42 PM Reply With Quote
There's a hole mid way up the block under the exhaust headers on the edge near where the block meets the gearbox.
I thought it was an oil blanked off but maybe it's water as you say?
Mark
Tiger Avon
jacko
posted on 2/3/10 at 05:04 PM Reply With Quote
A note to ME i must read the post properly
The plug you refer to under the exhaust is a oil return when a turbo is fitted [Cosworth engine ]
