daniel mason
| posted on 27/3/10 at 09:22 PM |
various items and advice wanted!
WANTED;
pair of sierra bolt on drive shafts.
pair of sierra rear hubs (bolt on)
pair of sierra rear bearing carriers.
rear discs to fit 13" rims and sierra handbrake caliper
ADVICE/WANTED
are all sierra rear calipers same size/ dimensions/bolt pattern?
if so i need a pair for my MNR!
all of the above are needed in good/ or as new condition! u2u me with prices if you have any of the items i need. paypal funds are waiting! cheers
| posted on 27/3/10 at 09:41 PM |
Two sizes of hub id hub Daniel... ABS ones do not fit the MNR uprights. The trigger ring fouls.
However, If you have access to a lathe its dead easy to turn the teeth off. Thats what I did and they fit OK.
Can't comment on using dics as I'm using a set of 10" drums off an Xr4 that are more than uo to the job!
And the rumours of using 10" drums where the hanbrake cable doesn't fit are not true. I'm using Landrover cables that fit a treat
(with a little mod)
Good luck,
[Edited on 27/3/10 by coozer]
daniel mason
| posted on 27/3/10 at 10:03 PM |
cheers steve!
austin man
| posted on 27/3/10 at 10:07 PM |
isn't the s200 RWD ? if so why not use the diff etc for the rear at least you know it will take the power. Im sure Steve Keenan has don this
with his Indy R running the S200 lump with supercharger
| posted on 27/3/10 at 10:08 PM |
With the warm weather coming Daniel are you thinking of having an open day?
Maybe we could have a blast over for a bit of social??
daniel mason
| posted on 27/3/10 at 10:15 PM |
feel free any time steve! my chassis is at mnr and am collecting it in 2 weeks! was there today for a few hours getting measured up for full cage!
austin man. i am using s2k shortened prop and diff. but you need to modify sierra shafts to suit honda diff!
