Wells
posted on 10/4/10 at 07:29 PM |
Hayabusa 2nd Gear Problem
I have just replaced the clutch in my car(OEM). Went a quick run and I think Its popping out of second gear a 9-9500 revs. It happens so quick though
I'am not sure. The only thing I changed when fitting the clutch was to fit clutch palls which I was told would give the clutch a more positive
feel. Does anyone have any ideas or come across this before?
daviep
posted on 10/4/10 at 08:12 PM |
Normally when bike boxes start jumping out of gear it's because the drive dogs have become rounded off. I can't think how changing the
clutch could be causing this but I don't believe in coincidence either.
Does it jump out under power or on the over run?
Does it stay in gear for a while or jump out straight away?
Is it getting worse?
Regards
Davie
Wells
posted on 10/4/10 at 08:59 PM |
It jumps out under full power. It doesn't seem to be getting worse but its only started doing it today. It only jumps out for a split second and
then jumps straight back in again. How dificult/expensive is this to fix?
posted on 10/4/10 at 09:12 PM |
Gear Selector is most common cause.
New one about £80 if fitting yourself...
ZX12 is half engine breakdown - likely same on Haya!
Normally caused by the biker in question reating foot on gear change...
daviep
posted on 11/4/10 at 07:31 AM |
My bet is still dogs being rounded, under power it should be virtually impossibe to get out of gear.
Regards
Davie
DIY Si
posted on 11/4/10 at 11:26 AM |
I had this happen on my blackbird engine. Wouldn't hold 3rd gear at all under power and it turned out the dogs were rounded. Cue me splitting
the engine in half and fitting all an new gear kit and selector forks whilst I was in there. Can't remember what it cost, but it was roughly
£150 to do myself.
Sun Tzu, The Art of War
