Author: Subject: V6 Type 9 Gearbox with long input shaft
jonny3979
posted on 20/4/10 at 12:02 PM Reply With Quote
As above - I was sold a short input shaft gearbox under the pretense it was the long version.
Based in Hampshire Local would be great but can travel and or willing to pay a courrier..
Many Thanks
Jon
djtom
posted on 20/4/10 at 01:01 PM Reply With Quote
I've got one from a V6 Sierra XR4x4 - I think that's a long input shaft if you fancy transplanting the input shaft into the 2wd box. It's supposed to be fairly easy, but I understand if you don't fancy it.....
[Edited on 20/4/10 by djtom]
mangogrooveworkshop
May have what you want........but you will have to wait till i get back to my lair....Im mobile at the moment....
Cheers pat
Mr G
posted on 20/4/10 at 01:25 PM Reply With Quote
You don't need to do that, just take the 4x4 tail section off and replace with the 2wd tail section, although you will have to drill the selector rod as they are different (you also won't have a speedo drive as there is no cog on the 4x4 to drive it - they drive off the front diff instead)
jonny3979
posted on 20/4/10 at 01:56 PM Reply With Quote
DJ Tom thanks for the offer however the further response from Mr G seems to remove that from my options. Thank you anyway.
Pat,
I await your reply.
Jon
dave r
posted on 20/4/10 at 03:24 PM Reply With Quote
i have one available
mangogrooveworkshop
posted on 20/4/10 at 05:41 PM Reply With Quote
Pat,
I await your reply.
Jon
yep got one here 30 quid and posty tax
jonny3979
posted on 20/4/10 at 07:34 PM Reply With Quote
mangogrooveworkshop you have u2u.
Many Thanks
Sounds just the ticket.
