Wanted: Push-in Driveshafts for 6.5inch Sierra diff
As the title says.
I'm thinking of doing a bit of weight saving. I've got the 6.5inch diff and its a good few kg lighter than my existing 7inch diff. Also
the ratio is an improvement for me.
So I am after a couple of driveshafts, the inner CV tripodes are smaller than normal ones. So, if you have some push in shafts that are too loose a
fit in your diff, then these are probably what I need.
I'll have to shorten them so condition isn't critical, but the inner CV joints need to be servicable.
I can do a swap for a pair of push-in shafts from a Sierra 1.8. These are full length, one of the boots will need replacing.
Thanks,
Matt
