Charlie_Zetec
| posted on 18/5/10 at 03:29 PM |
WTD steering bearing mount thingy
Well, I made a little booboo this afternoon. I am now after the top mounting section that hold the steering column bearing etc. (think it also has
the ignition barrel attached).
I don't need the ignition/key/wiring etc., just the bracket itself with the top bearing encased, can be from fixed or adjustable steering
column, makes no difference to me.
Please help, beer tokens on standby!!!!
gavin174
| posted on 18/5/10 at 07:27 PM |
Hi Charlie
can you post a pic of the bit you are after..
I have a column that snapper wants some bits off...
think he want different bits to you so might be able to help 2 people with the column if that makes sense
Charlie_Zetec
| posted on 22/5/10 at 03:07 PM |
To be clear, I (think) it's referred to as the alloy yoke with a pinch bolt and 2 mounting holes - bolts to the chassis.
| posted on 22/5/10 at 04:21 PM |
The bearing is in the ignition barrel housing, the yoke is clamped round the outside of the column and bolted to stop the outer turning. I got a
broken one from a Fiesta I think it was and I cut the ignition part off.
wilkingj
| posted on 22/5/10 at 09:33 PM |
Do you mean one of these?
http://nw.rhocar.org/supporting_the_steering_shaft.htm
Best Regards
Geoff
http://www.v8viento.co.uk
