Author: Subject: wanted twin 45s or 48s or 50s carbs
andrew
posted on 24/5/10 at 07:59 PM Reply With Quote
45/48/50/ twin carbs with pinto manifold
[Edited on 24/5/10 by andrew]
omega0684
posted on 24/5/10 at 08:06 PM Reply With Quote
48/50's
are you planning on dropping in a 2.4?????????
andrew
posted on 24/5/10 at 08:19 PM Reply With Quote
have you got a 2.4 ?
mookaloid
posted on 24/5/10 at 08:45 PM Reply With Quote
i think he means that unless you have a 2.4 pinto then 48's or 50's are too OTT
omega0684
posted on 24/5/10 at 10:24 PM Reply With Quote
^^^^^ say it like Mr Bean.......Bingo!
if you are running a 2.1 (a proper 2.1, 93mm bore) then 45's are the way to go. also depends on whether your looking for a carb or iTB set up. matched ported manifold to head will be required for maximum power with some BIG valves and top notch porting. i would strongly advise getting everything balanced on the bottom end also, crank, rods & pistons, fly and clutch casing.
depends how deep your pockets are for proper pinto power!
[Edited on 24/5/10 by omega0684]
cd.thomson
posted on 25/5/10 at 08:13 AM Reply With Quote
twin 50s on a pinto
andrew
posted on 25/5/10 at 11:23 AM Reply With Quote
my pinto is all steel max everything
